BG4004 platter does not turn anymore
Awhile back I noticed the speed on my BG4004 was a bit slow so I increased it using the trimmers.  The other day the platter stopped turning altogether.  I thought maybe the belt had slipped or broken, but when I opened it up the belt was fine.  Taking the belt off I tried it and the motor for the platter would not turn at all.  Everything else appears fine (the arm moves over to the record and drops to begin playing).  Any ideas or recommendations are appreciated.
I swapped out the motor with another 4004 and the motor worked in the other unit.  Could the trimmers be bad?
