Does a Beogram 4002 that has the optional built-in CD4 demodulator have different wires and plugs than the standard 4002? When I used to run CD4 in the mid-70s my turntable two wires plugged into the Panasonic CD4 demodulator which then had four wires that plugged into a 4 channel preamp. Does a CD4-capable 4002 also have four wires (plus a ground) to feed directly into a 4 channel amp? Other than removing the top and checking for the presence of a CD4 circuit board, is there another way to positively ID a CD4 capable 4002?
Kevin
