Hello All,
The 3v DC platter drive motor on my Beogram is very noisy (squeaky dry bearing sort of noise).
There is a back plate held on by two side screws. If I remove that can I get access to the end bearing?
Also, is the drive pulley just an interference fit? To get any lubricant into the top bearing, I guess it will have to come off.
Finally, what oil should I use on this (sparingly, of course)?
Thanks, again,
Simon
