BG 5500 vs BG 6500 MMC4
Dear B&O fans,
small questions:
Is the MMC4 from a BG 5500 compatible with a BG 6500? (Plug & play)
Does someone have a photo of a BG 5500 gears, how they need to be positioned to each other? I have a 5500, but the platter went off and I can't get the right position. Also the servic manual doesn't explain this. :-/
Thanks & kind regards for your help!
David
Yes all MMCs can be used on those two beograms, no problem.
Best regards
Christian
