Posted November 27, 2022 at 10:53 GMT
Hi again,
so far I spend probably a couple of hours (incl. some needed breaks ) with various magnifiers to scan across the main board in search of broken tracks…….nothing to see !
going back to the elusive -/+15VDC search:
At the anode junction of 1D21/D24 I get about -25.3VDC, at the cathode junction of
1D22/D23 I get about +25.3VDC.
after having tested the involved TRs and Diodes to produce the 15V lines without any adverse findings I really have arrived at a dead end …….!
what kind of AC voltage should I see at the junctions 1D21/D222 and 1D23/D24 ???
unless the board has suffered a particular nasty almost invisible hairline fracture it looks even more like another shelving exercise ?
so far only once very briefly have I been able to see the -/+15 VDC by giving P2 a serious wiggle - that was when I suspected a connection issue but…., that is only good if it can be reproduced which I can’t , no matter what.
the usual question, where from here -Shelf of Multimeter ??
ALF
