i just finished the restoration of my BG4000 but one annoying issue remains:
a thumping noise from the solenoid when activated ?
the coil resistance shows 8.7ohm, which is ok
the emitter voltage at OTR4 shows 2.7V
the associated resistor on board 7 has been replaced with a 8.2ohm, 1W resistor to be safe.
the current limiting switch has been adjusted to specification but……
I can’t get rid of that thumping noise from the solenoid.
sure, one could live with it by turning the amp’s volume right down for a sec but there has to be a reason.
can anyone shed some light on that problem ?
thank you
ALF
