Got a bit of an issue I’m trying to figure out. I am aware that the TX does not have a pre amp built in. I recently purchase one and plugged it into my tube amp of which my previous record player was played from however the TX does not output sound on this setup. I hear it playing from the needle so we are good there. So I’m not sure of the problem. My previous has a preamp installed but I had it turned off cause it was too loud and it still worked find. Do I need a preamp still if it’s already hooked to amp? And If so, shouldn’t I still hear it playing just at a low volume?
also will any preamp work? I was reading about preamps made specifically for the Beogram and wasn’t sure if that was a ploy or if it indeed does require a certain pre amp.
thanks for your help on this!
