I was doing a bit of work on the innards of my Beogram TX turntable and once I was done it was dirty all over so I started cleaning all the outer components. I got a bit too carried away with the isopropyl alcohol and started rubbing some parts down with it... all went well until I started rubbing the platter with it. I was in low light so I didn't notice till I had rubbed all over the entire platter, but the metal finish was completely ruined by the alcohol and the platter is unsightly now... I was wondering what model Beogram platters would be compatible with the TX (such as TX2 maybe?) and if anyone on here either knew where I could order a replacement or had one for sale.
Also, another platter-related question that I have is: are the rubber inlays supposed to actually come higher than the metal on the platter? Mine are totally level with the metal and my better judgement tells me that they are completely useless in this state.
Thanks.
