However, I've been struggling with a nitpicky problem. When I hit stop, the sliding chassis should confidently return to the park position. My sliding chassis does not return to a fully parked (all the way to the right) and will shake or chatter a bit. What I'm trying to describe can be seen at the end of the attached video
Login to view image
What I believe is happening is that the wires connected to the sliding chassis (blue) are applying a slight tension (to the left) that is keeping the sliding chassis from reaching the fully parked position. The chattering is coming from the gears on the underside of the sliding chassis drive pulley (yellow) not fully disengaging from the start/stop gear. The chattering will stop if I lightly push the sliding chassis to the right to help it fully park.
I've tried adjusting the wires to reduce the tension in addition to the normal setup adjustments. I've been able to reduce the chatter, but not eliminate it.
Has anyone else seen the issue before? Did you find an adjustment or fix?
Thanks,
Glitch
