Is there a way to adjust/tighten the angle where the lid holds itself “floating”. My RX2 is on a shelf, where I can’t open the lid completely, and I would like to adjust it so that it “locks” in the angle the shelf allows me to open it in - to prevent it from closing while I am operating the turntable, or if playing a record with the lid open.
Beogram RX2 how do I adjust/tighten the lid/dust cover lock angle?
You cannot adjust it. It is just a torsion spring, that holds the lid.
Okay. Thank you.
Okay. Thank you.
