Beogram RX RCA Cable Repair
I’ve owned my dad’s old Beogram RX since I absconded with it in 1997.  It’s survived multiple trips across the country, and years of regular service, but one of the RCA plugs just crumbled. I’ve done some research and it seems the best solution is to replace the plugs.  I found a supplier, but they sell plugs for a variety of cable diameters. Can anyone tell me which ones I need?
The cables are very thin, so regular ones should fit, and even if they are too large it won’t matter. See if you can get some without the need of soldering, where you use 2-3 small screws to tighten the contact between the copper wires and the plugs. Gives a much better result.ti
