I just acquired a fine looking RX 2 with a "simple" platter (did B&O offer this model with two different platters?).
Searching in both the owners and the service manual, I find no info on how to adjust the touch-down position specifically for the RX 2.
I've found that the manual is identical to the ones for Beogram 1800/2000/5000 and should therefore match the RX 2, but I cannot find "eccentric R or P" anywhere on the inside of my RX 2.
Screenshot of the manual snippet is attached.
Currently, the pickup arm lowers just shy of the record, slipping off and then onto the metal plate. Not good.
Please advice and thanks in advance.
