Hi guys i have a Beogram CDX that i bought a left hinge for and i want to replace.  Its a bear for me to take apart by going what the service manual says it says remove the play tab by making sure that the switch is in the off position well i think i have done that but how do you get it to come off??? i am worried about breaking the swatch. Also it tells me to short circuit the tabs on plugs on the main 74 plug  to stop the dust cover from operating well what it tells me and what it shows are 2 different things it says jump or short circuit from socket 53 pin to 4 to 51 pin 1 ground but what it shows is picture enlarged showing it jumping to 53pin 4 to 51 pin 2 not 1 so what do it do here? does it matter ? i am just armature here so Thanks
