I am struggling with a Beogram 7000 CD.
It started with does not read discs, runs after a short attempt in the wrong direction.
i cleaned the laser
Exchanged all capacitors on pcb30 (used also the blue 2103). A little bit better. But still not working.
exchanged the whole pcb from another working bo 7000. Worked
so the error is still on this pcb
exxhanged the two transistors 6124 and 6125
now it runs in the right direction and tries, but does not find the first track and stops
what other part on the pcb should I exchange? I don’t think someone screwed the 3106 or 3146 as everything was super dirty and looked original
best regards
69er
