Beogram CD7000 won’t play
Hi guys,
I am struggling with a Beogram 7000 CD.
It started with does not read discs, runs after a short attempt in the wrong direction.
i cleaned the laser
Exchanged all capacitors on pcb30 (used also the blue 2103). A little bit better. But still not working.
exchanged the whole pcb from another working bo 7000. Worked
so the error is still on this pcb
exxhanged the two transistors 6124 and 6125
now it runs in the right direction and tries, but does not find the first track and stops
what other part on the pcb should I exchange? I don’t think someone screwed the 3106 or 3146 as everything was super dirty and looked original
best regards
69er
Check the wires and sockets... the solder can be broken.
Login to view image
MMh,
i exchanged now also the third transistor on the PCB3, changed also another blue capacitor and checked the sockets. I resoldered some, but they looked good .
no change.
The player starts and then stops after about 10 seconds.
What makes me nuts - it needs to be on this PCB as with another one the player worked well.
What else could it be?
best regards
69er
Anything i could test or do additionaly?
Why does everone instantly starts te change capacitors when things are not working all of a sudden. With this cd player 99% of failing to read disk is a belt problem wich does not put the tray in the exact position. Change belt first...see what happens.
Greetings from Holland
I have never seen a tray belt cause a read failure.
If the belt fails, the tray will usually not open fully - or not open/close at all.
If the tray doesn't close fully, the disc will not start to spin.
The symptoms of the disc spinning for a few seconds, not reading and then stopping is a sign of a laser starved of power.
Replacing the capacitors on the servo board will alone fix this in 95% of cases.
The last 5% is usually dirt on the laser lens or a combination of the two.
If the disc doesn't start spinning at all, there could be a problem with cracked solder joints (as shown above) or
a badly seated ribbon cable for the disc drive.
The laser itself rarely dies. I don't recall ever replacing a laser in one of these decks, and I've done many.
69er, can you show us a photo of the board (front and backside)?
