BeoGram CD6500
Hello All
I have recently acquired a defect beogram CD6500. It so happens, that the CDs are trying to be read, but suddently the CD6500 gives in and stops.
I'v looked a little around in the forum, which seems to conclude, that the capacitors might be defect.
My problem is, where do I find these capacitors (if they are being manifactured anymore), or is there similar rated capacitors I could be using instead?
Regards Rasmus
I  have used link( https://www.elfaelektroniikka.fi/elfa3~fi_fi/elfa/init.do?item=67-062-53&toc=19198 )
link
