since a few weeks my 1987 beogram CD shows some "irritations" - meaning jumping around instead of playing smooth along. i´ve been to some entries where first hint is to clean the lense: i did that, it worked for ~ 4 weeks, then now again jumping; cleaned again, but no change this time :-((. the second hint is the belt for the drawer: when i had it open to clean the lense i checked the belt and it still seems to be Ok - drawer closes and opens without any issues. hint number 3 is now to exchange some dedicated electronical parts on the motherboard - and here my "do it yourself" will end: can anyone give me a recommendation where i could send my 7000 (best would be within germany, second best woudl be EU) and get it checked / repaired for a reasonable price? thanks a lot for you feedback in advance, and a happy new year, ralph
BEOGRAM CD 7000 defect ...
dear forum members,
Hello ralph,
My beloved CD7000 has been in the care- and skillful hands of forum member Beobuddy some years ago. I highly recommend.
He is in Utrecht, Netherlands.
Maybe an option for you?
Regards,
Johan
Regards,
Johan
hi johan,
thanks a lot for your feedback! do you hae any contact data?
best regards,
ralph
best regards,
ralph
Hi ralph, you can send him a private message, I did send you one too with some info.
Good luck!
Regards,
Johan
Good luck!
Regards,
Johan
