Hi Martin,
would you mind casting your eyes over my recent updates on this cd tray/ playback problem please?
I have tried out a fair few things from info i have gleaned.
It seems as per my last update after a few 'tray' adjustments via the service manual, breaking it down,
- i have found the cd motor spinning up way too fast, breaking the magnetic cd clamping thus the cd and magnetic puck run free inside the housing. When this does not happen, generally the cd player works for a day or two, then repeats the issues.
- The tray has intermittent open close problems, sometimes working then other times having various fits.
Most of these issues seem to all show up together, when one happens, so does the other.
if as you say i need parts replacing and soder joints checking, is there a service centre that would undertake this work relatively cheaply? This is a second hand cd deck and despite me being mostly annoyed with it alot, it sounds great when it does work.
Also i now have a 5500 receiver that needs its phono input rca sockets resoldering, so a place that can take these on, does it exist?
regards
Jon
