I have a random problem with my Beogram CD 5500 where it loads a disk then it sounds like the disk is jumping around the tray mechanism like a Mexican jumping bean! Then the CD player either becomes unresponsive, resorting to yanking the power on it and waiting for it to spin down, or it sends itself into standby mode.
The first time it happened i dreaded what i was going to find but it doesn't seem to be damaging the cd's at all?
Initially i found that the thicker cd's with full label printing on it worked better. My Bladerunner cd got loads of plays that day! Then other CD's with just simple track screen print on didn't perform so well. Also i find that some disks refuse to even load, for instance CD 1 of the Concert for Bangladesh refuses to even be recognised, then CD2 played just fine? Weird. Also, some burnt CD's refuse to play when others do?!?! I just don't get it.
I suspected something wrong with the cd clamping magnets, so i checked their magnetism (well these are 30 plus years old now!) but they seem to clamp when the tray and disk line up correctly. I have gingerly taken the puck off the top and placed some strong old hard drive magnets on it to 're-energise' its magnetism, maybe i didn't put them on for long enough but i didn't want to make it so strong that the loader couldn't cope.
I also had a play with the little green things on the back left near the power supply, that do something to the armature at the front that holds the clamping puck and lowers it into place, to no avail. (see piccy from another cd 5500 poster).
Then i had a brainwave and AHA! I found an old 2 part CD single card inlay and put that on top of the cd and lined up with the centre hole, this pretty much worked all day with that. So i bought a CD stabiliser made from carbon fibre, it worked faultlessly for a day THEN next day back to the Mexican Jumping bean CD's again!
Another thing that happens is sometimes the tray shoots out almost flinging the cd onto the floor, or it gets stuck half way in or out, or moves in or out VERY slowly. Then it sometimes sulks and goes into standby. I have looked at the tray mechanism belt and i'm sure i read somewhere that it does have a little 'slack' on it to give the tray that 'velocity' effect when the slack bites in. I cleaned the belt rollers very carefully with cotton buds. I also plopped some synthetic grease on the tray mech rollers to help its journey back and forth, again to no avail....I just don't get it!
Bizarrely some days it works faultlessly all day! I love its sound and its great with the huge master control star trek flight deck remote. And other days i have to give up completely and stream what i want to play. But i have almost 1000's of cd's i want to play again now i have finally got them out of long term storage.
HELP B&O EXPERTS PLEASE!
thanks
Jon
