I'm knew to the Beogram world, a good friend of mine has asked me to take a look at his Cd-50 with a faulty CD tray.
I did some research which led me to replace the black band between the motor and cogs which drives the tray mechanism. this has resolved has resolved the eject/loading issue - so far so good.
However it seems that the clip that holds the spring on the lower disc holder has lost the tabs which the plastic ring that keeps the spring in place have broken. Consequently the spring loader ring won't stay in play.
Login to view image
It is not clear from the service manual but I think the part number is 9132 "Disc Holder, Lower"
Login to view image
Would anyone have one of these available of have any suggestions - I don't really want to buy another unit for parts if possible.
Thanks in advance.
