hi all, help needed, i have a 2300 overture and a beogram 9500, now i have connected them up using an iconic RAII pre amplifier, yet i am only getting the use of one speaker and picking up radio signals. any ideas on what i'm doing wrong?
beogram 9500 and 2300 overture problems
One of my moderating colleagues has clearly got excited and deleted the wrong post! 😁
As said before, did plugging the 9500 into the 2300 directly result in sound from both speakers , albeit soft and tinny? Then the RIAA or more likely the connections are at fault. I would suggest that the problem is the DIN to RCA connection which will be connected to the wrong pins of the DIn plug. These connectors are directional and the one you have is the wrong way! What sort of connectors do you have - a picture would be good!
Hi Peter, sorry for the late reply, yes both speakers worked once the 9500 was plugged directly into the 2300. Could you recommend a decent RIAA preamp as the one I have isn't the best. I will send pictures of the RIAA and connectors this weekend as I'm at work till then. But honestly I want a better preamp. Thanks for you time and help.
Benny
I would get from
Thank you Peter, I'll check it out and let you know how I get on. Thanks again for your time and patiences.
Benny
I use a TC770LC fromCould you recommend a decent RIAA preamp as the one I have isn't the best. I will send pictures of the RIAA and connectors this weekend as I'm at work till then. But honestly I want a better preamp. Thanks for you time and help.
