Beogram 9000
Hi...
I am new to this site and a new owner of the Beocentre 9000.  I previously asked a question about turntables in the general forum.  Anyway...I am looking for a compatable Beogram for my Beocentre 9000...and wondered if anyone could steer me to the best direction here.
I have looked through Ebay, with no luck at the moment.  Is the Beogram 9000 difficult to find?  Is it a good match?
Any help would be appreciated.
Thanks.
Steve
I don't think it is a very good match - it is a standard square deck. The Beogram 3000 tangential deck has a sloping front like the Beogram 9500 and is also far easier to find. Mechanically, these decks are essentially identical.
I've never understood the design of the Beogram 9000, as a match for the BC9000 it just doesn't work. As Peter has already mentioned the BG3000 is a far better match along with the BG3300. Not only are these 2 decks a better cosmetic match but they are both likely to be a fair bit cheaper & easier to find than the 9000.
Chris.
At least we are all singing from the same hymn sheet!🤒
/forum/general-discussion-and-questions/beocentre-9000
