Beogram 8002 cleanup
Well...sadly...replacing the servo belt and cleaning the spindle didn't fix the issue.  I guess replacing the caps is next.  Seems odd that after operating the << & >> keys and watching the tomearm travel back and forth accross the platter for a few minutes would get the unit to perform normally.  If the caps were bad, they'd always be bad, no matter how long you moved the tonearm back and forth.  That's what made me think is was a mechanical issue.
Anyways...anyone know where to get a replacement set of capacitors in the US?
You can't get a "set". You need to get a cap kit that includes all the values you need. These kits are available on Amazon, DigiKey, Mouser, etc. Only do the electrolytics (the cylindrical ones) first as they are the most likely culprits. Don't forget the 47mF on the CPU board.
Got an Amazon link?  I'm not finding anything that would be worth buying.  There are many assortments that contain a whole range of capacitors (most of which wouldn't get used).  Is that what you mean when you say 'kit'?
If you are going to buy a capacitor kit then buy it from
Yes that is what I meant. I do see that Martin has an 8002 Cap kit at https://www.beoparts-shop.com/product/capacitor-kit-beogram-6006-8000-8002/ I have gotten parts quickly from him in the US.
OK.  Cap kit has been ordered.
Update!!
Cap kit installed and the turntable operates like new again!  Had to disassemble it twice because of a loose connector but all in all, not as difficult as I thought it would be.
Thanks for your help!
Great to hear! Keep 'em spinning.
