I have just joined Beoworld after acquiring an 8002 with an MMC2 for a reasonable but not cheap price (£650) from a dealer on eBay. Although it was serviced (last November), it has issues (which might be down to handling in transit, although it was well packed and the box didn't look as if it had received rough handling).
The first is a hum problem, but that will hopefully be solved when the new DIN to Phono arrives from Steve at Sounds Heavenly - whom I came across thanks to a perusal of this forum :)) The 8002 is currently playing into a Naim SuperUniti via a Project Phono Stage pre-amp. Ignoring the hum, the sound is pretty decent (I also have a Rega Planar 3 with RB300 arm and an Ortofon MC10 Supreme, although the cartridge is on loan from a mate).
The main issues are with the sensor/tone arm. When you press play, the arms move to the start of the LP (or 7"), there is a fair delay before the stylus arm drops (quite quickly I might add) and often it misses the edge of the record. Once you position it and it plays, it will play the whole side of the disc without issue and then return to base.
However, if you cue the arm to play a particular track on the disc, it will play for a few moments and then the arm will lift and return to base.
Any suggestions greatly received. If necessary, I could try to upload a video of the arm's behaviour.
Doubt the deck has ever been recapped. What's the name of the guy who can provide the set of capacitors. I'm going to get the guy who services my other old equipment to take a look at it and he is researching the 8002. My problem is that shipping it from the Channel Islands to the UK (or elsewhere) is expensive and there's the risk of damage.
Thanks in advance for your input.
