beogram 8000 TT only
These decks can be made functional (although longevity is not a guarantee) with a parts machine as a donor
This has never worked for me... Eventually, I always fix the donor machine and it becomes a spare/backup machine ;-).
Thank you Glitch for this advice.  Meantime I sliced the front off this cartridge where the cantilever had broken off.  Surprise surprise it is the same structure as the old SP6 with a little X stuck on rubber block and the cantilever secured to the X.  The pole pieces are in a block of green rubbery stuff but they made this as a sealed unit unlike the old SP6 where the front comes off and gets replaced.  If I can make a tiny X and secure a cantilever n needle to it, I can mount the X on the rubber and this thing will still work.  If I touch pole pieces with ferrous tool, the speakers thump left n right.  X structure n cantilever on SP6 is much too large to cannibalize otherwise I would buy one and get it on here somehow.  If somebody made it farther than I have already, thank you for tips.
It won’t work. Completely different contexts, with incompatible characteristics.
Are you trying to save money or do you want a great deck ruined by a DIY mess?
Buy a new cartridge from Soundsmith and enjoy the music ?
Jacques
Pictures please.  I, and likely many others, find it very interesting to see the inner workings of things that people normally don't cut apart. It also might be worth a search of the forum history to see if anyone has tried this before. One of the more recent similar threads is Glitch
