Can You send a picture of where the teflon pad sits?
Jenku
Jenku
Are you referring to the pad for the dust cover hinge as pictured at the top of this page?
-sonavor
Yes I am.
I found it floating around in the bottom of the case.
I can't find any marks on the plastic wall where the teflon used to be due to a lot of grease added by the previous owner.
So is the plate going to sit right op to the bend or way down?
Regards
jenru
The second picture on
Ups! I thought that the square piece 1x1 cm. mentioned was the teflon plate.
Now I know better.
The metal piece is inseted in the cover hinge for the small end of the leaf spring to lay upon.
Regarding the Back Part (From the Service Manual: item 003, Part Nr. 3030067) Dillen advised me to glue it to the frame which I did.
Because one never need to take it off.
Cut out a small corner of the back part and you can remove the pin that hold the lid.
Jenku
How do I add Pictures to my answers???
Jenku
Jenku
A couple of ways. If you have just one photo you can use the Options tab in the Reply screen to Add a photo from your computer. There is a size limit though.
Another way is to go to your Beoworld Profile and use the My Files section to create folders for uploaded photos. Once the pictures are uploaded there you can use the Insert Media icon on the Reply editor box to insert multiple photos (from your My Files section) to the reply.
-sonavor
Thanks for the quick answer.
By the way, where can I find out what kind of tape on the backside of the keypad protects the cobber contacts?
Or can I use plain electrical tape:
Jenru
Jenru
You don't want to use electrical tape or similar plastic tapes. They are too thick. It is best to leave the original tape but if you are in a fix where you absolutely have to replace it then I have used a thin foil tape. Something very thin. Maybe around 3 mil. in thickness. If someone knows of an equivalent tape to what Bang & Olufsen used I would be interested in getting some as well. The tape is there to prevent dust from getting inside the contacts but has to be thin enough to allow the buttons to actuate the contacts.
-sonavor
Hey again
It's funny that the tape is there to prevent dust from getting inside the contacts cause it can enter from the othe side through the small gaps for the contacts legs.
There was no tape on six of the contacts neither tracks of any tape so I found some laying around and added some strips.
In the picture it' the lighter tape to the right and the contacts are working flawless.
As You can see, the is so thin that one can se the PCB tracks.
Regards
jenku
