Hi ALF,
Was the LED in the tonearm on during both measurements?
Assuming it is, then 1TR6 is not being biased on properly and the only way for the LED to be on is for 1TR6 to be faulty. I'd pull it and test it.
Regards
Lonnie
Hi ALF,
Regards
Lonnie
Are we talking about the transport indicator arm LED ?
if YES, this LED only comes on at << or >> or 2xPlay flashing.....not during this particular meaurment !
i measured twice with ground from chassis and ground at minus of C27......in both cases the outcome is the same.
ALF
Hi Lonnie,
just answerd that....if we are talking about the transport indicator LED then the answer is no in both modes!
what is however on all the time is the bulb in the photo control part as power wonβt be properly turned off.
i will test TR6 tomorrow, its getting late π΄
ALF
TR6 is fine.
Hi ALF,
Sorry, I thought you were indicating that the LED in the arm was on all the time. Re-reading you post you clearly say servo bulb.
As Dillen indicated 1TR6 is fine so no need to remove and check.
Regards
Lonnie
So it sounds like this Beogram can go into a pseudo standby mode where the microcomputer thinks it is off, the standby LED is on but some things are actually still being powered - the servo light and the brake circuit. Maybe the microcomputer being in standby is causing it to ignore any platter rotation information coming in. The brake circuit is trying to brake without any feedback so it just keeps going and the platter is driven in reverse.
Check the Β±15 V supply lines when the Beogram is in standby and when in play.
Hi John,
i checked all +15 V / -15 V points
STBY/STOP PLAY
TR19-C -17V Around -15V
P2 - 9 15 V 15V
TR15-E 15V 15V
P4-8/R46. 15V 15V
C8. 15V. 15V
TR30-C. 15V. 15V
TR29-C -17V. -16.5V
TR1/TR3-C. 15V. 15V
ALF
What about P3-4 ?
Sorry John, I missed that one:
P3-4: StBy/Play = 14.9V π
ALF
That is the power for the servo sensor lamp. That should be off when in Standby. Tonight I opened the little black lid in the tonearm compartment of the Beogram 8002 in my office. The servo lamp is off when the Beogram is in Standby mode (which is how you would think it should function). If I press Turn or Play the servo lamp comes on. Pressing Stop returns to Standby and the servo lamp goes off.
Some signal(s) in your Beogram have the microcomputer and logic confused where part of the Beogram is in Standby mode and other parts are not.
John
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
