Hi ALF,
I would've been very surprised if you did have a current probe.
It's still an interesting measurement. I presume the light blue trace is P4-2, anyway it shows that the brake is being activated.
Regards
Lonnie
Hi ALF,
Regards
Lonnie
Yes that is interesting to see the waveforms at the two connector pins. I am still puzzled by your test where you lifted 1R108 to disconnect the microcomputer pin 37. You reported
"...deck does not power-off (servo light bulb still on) and the platter motor still shows some very gentle stuttering clockwise".
I would have expected the Beogram to start up in Standby mode and stay there. I wonder if this is another symptom of what is wrong with your Beogram. Again, sorry I can't try the same test here to compare but maybe Lonnie is in a position to test it on his.
sorry, but every little bit is as described
here are two better pics of P4-1 / P4-2 - blue line = pin2. yellow line = pin 1
first pic is during PLAY mode, second pic is at STBY/STOP
this is the second pic STBY/STOP mode
Hi Lonnie,
perhaps a side issue, but measuring 0S1 in open position should not deliver a finite ohm reading but should rather show OL on the DMM ?
i do not understand why this is not showing !
ALF
Measuring across the open switch in this case is measuring into the Beogram. The impedance is whatever the attached circuit is where you are measuring. It won't necessarily be OL as you would get with the DMM leads measuring across an open switch no connected to a circuit.
Hi ALF,
John's explanation is correct, you'd have to take the switch out of circuit and re-measure it to see an open reading.
You previously gave readings at P6-10 to confirm the voltage when the switch was open and when it was closed. Those voltages were fine so the switch is operating as it should.
I'd be interested for you to measure the voltages around 1TR6 which controls the LED in the tonearm. What are CBE voltages during Stby and Play? I'd like to know if the uC is biasing 1TR6 on the whole time.
My daughter has custody of the TT in her room and she loves it! However, I'll try and pry it away from her and take some further measurements over the week-end.
Regards
Lonnie
Yes, of course, John is absolutely right !...I should have known that....just brainless fishing for a cheap answer or desperation ? 🙄
i will take the measurements around/at TR6 and report back.
good luck with the daughter......’s TT I mean 😁
ALF
Hi Lonnie,
did measure at TR6:
C B E
STBY. 45mV to 595mV. 5.05 V. 5.07 V
PLAY. 10mV to 695mV. 4.98 V. 5 V
what was interesting is both modes at C the voltage steadily climbed up to a max and fell again?!
ALF
These voltages should see the LED off in both stby and play.
I lean more and more towards a broken PCB track, perhaps a missing ground somewhere.
When you measure these voltages, where are your ground lead connected?
