Hi Lonnie,
replaced without the desired outcome 😡
I feel like simply integrating a hand-switch in the mains cable and live with it ?!?
what else is left that would make sense to replace ? Unless my peak tester lies, is faulty or all replaced transistors were fakes
there isn’t much I can do about it.
Is it really that far fetched to suspect the uP ??
I played a record this arvo and the deck performed nicely minus of course the never stopping anti clockwise spinning platter after record play-out stop......!
I can not think of another fault source, can you ?
All transistors are put in the correct way, no mix ups between NPN and PNP....no solder bridges and no detectable broken tracks.
I have to trust the DMM readings, what else can I possibly do.
ALF
