Hi Lonnie,
it is not just replacing rather than precaution - desoldering components means additional heatstress - the last I need !
while I check/test those components I replace them with a new selected component.
If a test shows a faulty component I would have had the culprit by now but sadly, not so far 😕
i am aware, not always is a test conclusive and the faulty one could slip through.....me without knowing there was a problem.
but looking at the range of replacements, they are either all faulty or I/we are barking perhaps at the wrong tree ??
remember, starting with PLAY after hand-braking the platter everything seems fine....would that suggest that 0TR1 has a short ??
sure, I will measure again around those mentioned components and come back 🙄
ALF
