Well, my Beogram 8000 is running fine but I just got my 7 pin DIN to RCA with separate ground today. I hooked it up and the table sound ok but I get a hum from the right channel and the upper highs seem to be missing, the cartridge sound good with very good center imaging but that hum in the right channel is driving me crazy. It's not really noticeable and lower volumes but when I turn it up a little the right channel hum is loud. I disconnected the table and the hum went away so it not the phono preamp. It sounds like the right channel is not grounded.
Could this be an issue with the 7 pin DIN to RCA? Also does that shinny plate under the cover below the tonearm in rest position have any thing to do with this because mine is off at the moment? I will check all grounds from the RCA to 7 pin DIN and back into the deck. I hope it's not the cartridge.
Anyone here had this problem? what was the issue?
