Hi
ive used Martins great kit and replaced all the caps as per instructions. The only issue now appears on cueing the arm. Pressing play moves the arm to the correct position but it wont lower. It lowers if you move it on manually a few mm withe the << key and works perfectly??
Any ideas?
Andy
