Hi all,
I am currently restoring a Beogram 8000. I changed the caps, resoldered joints, replaced a defictive IC.
Luckily this unit has a metal tacho disc. However I am quite sure the light sensor has gone. (Call it short circuit or overload of the led or just mechanically, it simply doesn't give any sign of life)
I have read in one of the threads that the light sensor of the tone arm has been repaired with some units of an old computer mouse. Can I use similar components for this sensor or does it need a special kind of light sensor. (What will be the type?)
Thanks in advance!
