Beogram 8000 - Cannot Adjust Platter Height Within Range
Hi All,
I've cracked the case. It turns out that the combination service manual is riddled with errors. Many of the measurements given apply only to the Beogram 8002, not the 8000.
I have got a copy of the service manual for the Beogram 8000 specifically and it says only to adjust the platter till flush with the top. This I can do. It also incorrectly gives a sensor arm height of 19.5mm when it should be 23mm for the Beogram 8000.
Please see the attached screen capture of the correct service manual.
Cheers,
Gnab
Hi All,
Thanks for all the help and suggestions also, I appreciate it!
Cheers,
Gnab
Wrong post, sorry.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Gnab:
Which part of the case did you crack?
The 8002 uses a completely different platter, different stylus and tone arm than the 8000. 8002 platter has no rubber ribs.
Derek
Hi Derek,
What I realized was that you are not supposed to adjust a Beogram 8000 for a 2mm platter height. The manual I had claimed to cover the Beogram 8000 but many of the specified measurements were for the Beogram 8002.
A review of the dedicated Beogram 8000 manual and the beolover website revealed this to me.
Hence I could adjust the platter height to 2mm because you're not meant to.
Cheers,
Gnab
