I recently purchased a Beogram 8000 and I have completed an electrical restoration and inspection. I am now working through the mechanical/electrical adjustments. I have been able to adjust everything within range with the exception of the height of the turntable platter itself. I cannot adjust it for a 2mm gap.
For some additional context, I purchased this turntable from a collector and at some point, someone opened the deck and fiddled around a bit.
The issue is that when I adjust the suspension springs the conical travel lock posts collide with the deck long before the platter achieves an even 2mm lip all around (the screws on the travel locks are completely wound in also). At best I can get about 1mm and at the point, the travel locks are pressing into the underside of the deck such that the suspension is no longer doing anything useful.
I have inspected the whole deck and I cannot see anything that would allow me to fix this issue. Thus I can only conclude (without further advice) that either this is a manufacturing tolerance issue or I am missing a small shim on the hub spindle (this would raise the platter somewhat relative to the suspended sub-chassi.
Based on a review of the parts catalog I don't believe any parts are missing but I note that it is not the clearest parts catalog I have ever seen so I may be missing a shim or something similar something.
This appears to be an earlier deck as I had to replace a worn tacho disc as part of the restoration.
Can anyone shed some light on this as I am a bit stumped?
Cheers,
Ganb
