BeoGram 7000 and BeoSystem 3
yes, the beogram has a 7-pin Din connector and the cable looks original and cannot be unplugged. But you are right, the problem is somewhere at the beogram. Attached are two oscilloscope traces from the overture aux/pin 7. It sends 2 times the same 'start' signal. Interestingly, it is the same sequence - once triggered by pressing AUX in the overture or PHONO on the Beo4....
Looks like I have I have to open the Beogram......
Just remeasured. Pin 6 and 7 is the same signal at the overture. Will open the BG5500 and check the cable.
Thanks for all the help.
Just a quick update,
could fix it. Installed new din-plug with the yellow wire to pin 6. So cool to control a beogram with the overture ;- ....now I a have to search for a riia preamp.
Thanks for the help.
Great to hear you worked it out ?
