Hello again
My answer is assuming you do not have an other audiomaster product connected to the Masterlink of the Beosystem 3
Thanks a lot of the info and yes, I ideally would like to control the beogram with my remote. If I were to source a BeoSound Ouverture would it needed to visible to the remote or would that be handled by normal BeoSystem IR interaction? I would really like to go for a minimalistic look, basically just the BeoGram visible. Today everything is hidden away in my cellar and so only cables are run for IR and speakers.
The advantage of using datalink and masterlink is that the control signals are transmitted in the cables, and therefore you don't need the IR eye on the BS overture to be visible, and don't need separate IR cables. You do however need to setup the Beossytem 3 to accept both video and audio commands by putting in in option 2. With a BEO4 press: Standby + list at the same time. the press list unitil option? is shown in the display, and press go. It will now show V.opt, the press go and 2. The Beosystem 3 should now be in option 2 and accept both audio and video IR commands.
Depending on how, or if you want to use the Overture in the room it is going to be placed it could be set at different options. Option 0 it will not react to IR commands. Option 1 it will only react to audio commands, and option 2 it will react to both audio and video commands, and thereby let you have sources from the Beosystem 3 played through speakers connected to the overture if you want to do that.
BS3 -> ML -> BeoSound Ouverture -> DL -> Beogram X?
That is the correct setup. You might need a 7 Pin datalink extender cable if you place the Beogram and Overture in different rooms.
