Martin wrote:
Regarding re-cap, is is often necessary on these Beograms? If so, are there any recommended brands and their values floating around the forums? Could be good to know for reference if any problems arise.
Would you say that tweaking the RIAA made any noticeable difference? What kind of tweak by the way? :-)
Apart from the filter capacitor on the power supply board (known to short circuit if of the Roederstein brand), there are not really any common problems with capacitors in these decks. And not a lot of capacitors at all, really.
The sound reproduction of the RIAA preamplifier can be changed slightly by replacing some of the capacitors on the RIAA module, but that'll be a matter of taste rather than a matter of failure.
A better "tweak" (and one that can be proved technically) would be to replace the opamps with better spec'ed ones.
But - again - that will not be because of failure, or even because of frequency response, but mainly because of s/n specs, which rarely any owner would notice anyways.
These Beograms are excellent performers in their own rights, and beautiful design pieces at that, but any serious vinyl afficionado would've chosen a different deck altogether rather than trying to "tweak" something out that never was there.
The best tweak you can do is use a good quality cartridge.
In other words - if your cartridge was less than, say, 350-500 euros or thereabout, your focus should be on that long before any other "tweaks".
