Noticed that I now have a scraping sound when playing a record and once it's around half way through which increase slightly the closer the pick-up arm system gets to the end of the record. There are no cables loose or anything else which can generate the audio so clearly something around the mechanism for the pick-up arms system which generate this scraping sounds; just that I can't really why it's generate and it's only generate 1/3 - 1/4 of the record when spinning so it's almost like that it something might be skewed. But, it looks fine. Having said that, I did notice that the plastic casing for the pick-up arms system isn't fully aligned:
