just when I thought everything is back to normal…..it isn’t !
press Turn and the pickup arm moves to the drop down point,
press Play and the PUarm lowers and immediately rises again, goes back t9 its resting position, rises the PUarm, lowers it again and after some attempts of pressing Stop the arm finally goes to its resting position but stays in powered position.
while this is happening I can hear the spindle attached to the servo motor tries to klick into gear after a couple of tries and finally manages to do so…..
it is quite difficult to explain what is happening here and I wonder if it could be a fault microcontroller (the 24-pon chip on PCB 1) ?
none of the gear wheels is damaged, the magnetic coil on PCB1 is ok
to the point: I have no idea what is going on and what is causing that
erratic performance.
can anyone shed some light on this problem ?
ALF
