i am struggling with my Beogram 6500 turntable, no output signal at all.
it looks like the RIAA board is ok and the cartridge is fine which led me to believe the mute switch
might hung itself?
i disengaged the little spring which helps the leaver to push or release that switch so it is now open but still
no sound.
the RIAA board is getting supply voltage…..so, what else could it be ??
would some of you have any pointers for me what else to check ?
that would be great, thank you
ALF
