beogram 6006
Hi I have a beogram 6006 which when play is pressed it goes to the first track and plays fine. The problem is it won't allow manual cueing (<<,>>). Any ideas?suggestions would be great.
Thanks chris
Thanks  I will have a look and let you know how it goes.
Chris
Hi i checked the lamp and you were spot on thanks,it looks like the cueing works with light dependent resistors ,and the bulb isnt working thanks.
But when i put it back together and press the play button the turntable starts and the tonearm moves in about 10 mm and stays in this position,spinning but unresponsive when any buttons are pressed,have you seen this before.
Thanks chris
Thanks chris
Sounds like another symptom related to the same fault.
Note there are some adjustments to make after replacing the lamp.
The lamp is a silly spec'd one if I remember correctly.
I have correct lamps in the drawer.
Hi do you know the correct lamp and where i can get one also after reading alot in the forum on these turntables do you know where i can get a capacitor kit from .it looks like a long haul referb to get these upto original spec,i will take pics of the processes and post them if its ok for future reference of users.
Thanks chris
Well Chris,
As stated above, I have correct lamps in the drawer.
And I'm also the guy, who made the cap kit.
PM me
(or google around a bit if you prefer).
Thats great news,could i buy a cap kit and bulb from you please let me know how you want paying .thanks,chris
I sent you an email.
Hi im really sorry to be a pain but i tried to open up my email account and its locked out for some reason so i couldnt get your email.i have created a new account and updated my info on beoworld my new address is *.
Thanks,and sorry again chris
