Beogram 6002 strange sound
Thank you, yes I also believe it is a wiring problem. So maybe I have a fine working pickup :-)
I have never opened a Beogram before, so I will se if I can find somebody to help me out.
Thanks again for your help
Carl
I work on Beogram 400x and 800x turntables so I haven't opened a Beogram 6002 either.
-sonavor
The problem has been found and corrected :-)) It is very strange, and it looks to me like this Beogram has left the factory without being tested.
The reason was that the ground pin in the DIN female plug inside the Beogram, pin number 2, was simply missing, and therefore the reference ground was not connected to the cable, giving this very very weird problem.
I connected the ground wire to the chassis ground, and voila, everything is now working so beautiful. Probably the cartridge is brand new, because it must have been impossible to get any tone out of it previously.
Thanks for all the answers, it has been so helpful.
Carl
Hey Carl621
I know it's been a couple of years since You posted this about Your Beogram 6002.
I have this problem.
The four wires to the platter motor are broken off.
Do You by any means have an idea where the wires are soldered to the platter motor PCB?
Regards
jenku
