Beogram 6002/6006/8000/8002 Hinge/bracket - Have anyone created a 3D print?
Hi
Hope that someone here can help me. I am in the middle of a renovation of an old Beogram where parts of the hinge system that holds the dustcover open has gone missing. Now the hinge is the same for all of the above mentioned models.
In the service manual it is listed as p/n: 3030048. However in the 8002 manual it is not listed with a p/n but I am guessing it is part of the p/n: 2542527 - called hinge. To give a better description it is the part that attaches to the leaf spring that then attaches to the hinge on the actual dust cover. Now, I am Danish and have looked across the Danish part market which I assume is the largest for Bang & Olufsen and it is nowhere to be found. However should anyone have one then please feel free to contact me..
HOWEVER, I am hoping that someone maybe have created a 3D print version of it - and that they would be willing to share the file.
As I don't have the part I cannot scan it or replicate it.
As a general side note, we (the people that wants to keep the old B&O stuff alive) should try to recreate parts that cannot be had any longer with 3D print version. So, if someone have a 3D scanner and access to parts then here is a way to keep busy going forward.
Thank you in advance..
Ok - I am guessing I have to lower my expectations. So, is there anyone out there that could take a couple of good photos of
the "Hinge" - again it is the part that attaches to the leaf spring - not the one attached to the dust cover.
If I could get some photos - maybe even with a ruler next to it I could then try to create it myself.
Thanks..
