Press Play, arm moves to record, drops and plays all the way to the end, lifts and begins to return but becomes stuck. When I looked at the mechanism, I found that the arm pulley (1634) and cam gear (1636) had become misaligned and were binding. After repositioning these, the arm worked normally for a while. But then the issue recurred. Has anyone else experienced this in the 5900 series? Short of a worn part or a strong shock/hit to the turntable, I can't see what would cause these to become misaligned again on their own.
Login to view image
