I have a beogram 5500, is overall good condition. I have to raise the turnable to lift it up as it use to scrape as it went round. This worked but as you look at the pickup arm it rises and falls as something is not flat.
Taking a little more time to investigate, it appears the brass shaft that is attached to the floating chassiss and holds the turnable is loose.
How can this be tighted or should I just use a little glue to hold in place and remove the movement?
Many thanks,
Darren
