beogram 5500 turntable repair, gear disassembly?
So far I've replaced the 2x 10,000uF caps in the 5500 amplifier, and most of the big caps in the 5500 CD player. The 4700uF I ordered was too tall for the CD player PCB to close down again ( doh!! ) so will have to order a shorter one.
The 5500 TT parts are here, will take a stab at it later today.
At least I have music now :) the CD player is running, I'm curious if it'll get warm like before. I need to order a belt for the 5500 tape deck, too. Motor spins but I assume the drawer belt has stretched/dried out, as it won't grip.
Thanks again, for all the help!
I tested the regulator compared to a new one, and thought it was bad. I'd like to kick the sadistic engineer who designed the regulator mounting system in the groin!! What a stupid setup. Why didn't they just screw it down?
Anyway after new regulator, new 1000uF cap C3 & new 1uF cap C4, I am still not getting any voltage out of the power supply.
So I'm thinking it must be PS diodes, or there are 2 other caps in there, on the schematic. Hopefully the power transformer is good. I'd think the fuse would have protected that though?
Ps do I need to have the TT hooked up to the rest of the system to troubleshoot this? I assume just plugging the power cord in should give me something to work with?
Thanks for any advice!
