Another problem noticed with old 5500 Beogram. The speed changes slightly during LP play. It can happen at any point of the play. It is hearable in the music and really annoying when it happens.
I suspect that the belt of the motor-flywheel is worn too much or gotten a bit longer, since it is the original belt. And this player has been stored in below 0 temperature at one point.
I noticed that the belt does not stay in center at the motor axis side. BTW why it is shaped elliptical, the part at motor axis where belt runs ?
Can someone confirm this that its only the belt problem. I would appreciate if someone has the knowledge of this.
I try to add couple pictures to illustrate what I mean. Belt in the center or dropped down of motor axis.
Ismo
