Hi There
I have just seen your post, I have been for a long while been looking into the best way to restore plastics, Piaf has mentioned Micro-mesh and we have been discussing this in other posts. I have been in negotiations with the company that produce Micro-mesh about the products and they offered me a post of becoming a private seller with them because of the work I was doing. Since I met with the company and the other methods of restoration I use I have thought of offering this as a service to Beoworld for this very problem, damaged plexi glass. I have restored quite a number of turtable lids now. Piaf used the Micro-mesh after we talked about this and he was happy with the results.
I have been offered a discount rate with the company here in Glasgow because of the work I do to restore plastics etc. I am currently repairing a very scratched BEOGRAM 3500 and I have a selection of photographs from start to finnish. I have at the moment removed id say around 90% plus of the scratches that were on the plexi-glass. It is very tricky and I would say that you could be disapointed with the results if you are not careful. the trick is to avoid creating more scratches when you are working back to create a fine polished surface once most scratches are removed, there are certain ways that I do this but it has taken me some time to develop my own way of working.
I also use a range of optical glazes once this work is done to protect the surface.
Do you have any pictures of the Beogram with the damage in view as I am more than willing to help and also supply you with Micro-mash if you wish to proceed. I have my own photos of restoration which you can have a close look at if you like.
Hope this helps and feel free to ask anything you want about restoring the Bg 5500
Kevin
