BeoGram 5005 tonearm too low
The spring is responsible for restoring the arm to its rest position. It appears you can move it to the proper level with your finger; therefore, it appears the spring has lost tension or was switched with one of the other springs. You should be able to confirm that by pressing on the spring’s top connection. The other possibility is that the counterweight is too far forward which for the tracking weight calibration. Ensure that when the tracking force know is at 0 that the arm floats when in Play mode.
I don’t think the spring nor the counterweight are the problem.
I had another study of the service manual 6.6 and it appears the Schneidenlager B is missing. I couldn’t take a picture of it, but it feels flat. I think this is what’s causing my tonearm to hang low.
Now does anyone have any advice on how to go about fixing this. Can I glue something on, can I 3d print something, or do I need to start hunting for a replacement part?
Any advice, recommendations are welcome.
Thank you.
Best,
Tom
Thank you.
Best,
Tom
Your picture of Part 1110, Holder, appears to be missing a rear piece S that sticks up and may have snapped off. The only solution would be to find a replacement.
Hi Mark,
When I compare my part 1110 with the picture in the service manual it appears to be OK. Both S pieces (the two little sharp cones) are there.
Can you please tell me/show me which part you think snapped of part 1110?
I still believe it has to do with "Schneidenlager B" of part 1108.
Does someone have a picture of the underside of part 1108, that I could compare with mine?
---and if anyone has any suggestions on how to fix/reattach that pin "Schneidenlager B".
Thank you.
Best,
Tom
Thank you.
Best,
Tom
Relooking at it the second pin may be there. However, if you had an issue with the knife-edge bearing B not being there, the arm would not work at all. It’s possible the are was not properly refitted. Try following these steps precisely again:
Login to view image
Login to view image
Hi Mark,
I am afraid the edge bearing B appears to be missing in my beogram 5005.
How can I fix this?
best,
Tom
How can I fix this?
best,
Tom
I believe that bearing is part of the arm assembly and is not available separately. You will need to replace the entire are or find a parts unit. Most B&O tonearms were a single part number.
It's cast metal.
It can come out if you heat it carefully, not melting the plastic, only softening the glue.
Hi Martin,
I am not quite sure I understand.
Are you saying you would try to take out bearing T (is this the connected top side of the cast metal pin on the bottom (edge bearing B)) and replace the complete cast metal piece with something else?
Before I take the whole thing apart again, would you have a picture, that could explain what you are suggesting?
Thank you for any help.
Tom
Tom
Ok, I have taken it further apart and took some more pictures.
Does anyone have the dimensions of the original edge bearing B part please (and any suggestions to bond a new pin to that surface)?
Thank you.
Best,
Tom
Thank you.
Best,
Tom
